DCX32-5S SECONDARY HYDRAULIC SYSTEM FAULT! HYDRAULIC FLUID MAX TEMPERATURE REACHED.
Typically caused by the hydraulic fluid level being too high in the auxiliary system provided by Cytec on the top of the ram.
Give the fluid time to cool.
Check to see if a pressure sensor has failed, causing the accumulator to hold extra fluid that is then pushed through a bleed-off valve which causes the temperature to rise.
