Error Search Result: error_notification_0321
C-AXIS STARTUP POSITION FAULT! POSITION ON NEGATIVE LIMIT OR C-AXIS POSITION HARDWARE ISSUE. SEEK HURCO SERVICE HELP.
The string potentiometer on the C-axis has failed and must be fixed. The axis was moved to the negative limit while uncalibrated and needs moved away from the limit. There are for main areas that can break:
  • Ensure that the string has not broken.
  • Ensure the clamping device has not broken.
  • Ensure that the string potentiometer has not failed.
  • Ensure that the decoder is not broken.
