Error Search Result: error_notification_0323
C-AXIS STARTUP POSITION FAULT! C-AXIS POSITION HARDWARE ISSUE. SEEK HURCO SERVICE HELP.
C-axis is not in the correct position.
The string potentiometer decoder has a fault and does not match the actual position.
Check the output of the decoder and verify that it is a valid output. If it is not a valid output, replace the decoder unit.
