Error Search Result: error_notification_0324
C-AXIS FAULT! CHECK ABSOLUTE ENCODER OFFSET.
C-axis is not in the correct position.
The C-axis string potentiometer says the axis is between -30 and 30 degrees but the machine position is -30 degrees or greater than 30 degrees.
  • Determine the correct C-axis offset position and change the home offset of the C-axis to match.
