Error Search Result: error_notification_0012
ATC ERROR – MAGAZINE IS NOT IN POSITION.
When the ATC magazine rotates, an error can occur if the magazine does not reach a sensor in the expected amount of time or if the magazine is stopped in between stations.
This error indicates that the ATC magazine failed to see the end position sensor in the time allotted or is stuck in between sensors.
- In WinMax, go to the ATC Diagnostics screen and attempt to jog the magazine counterclockwise and clockwise to get the magazine into a known position.
- Inspect the end position proc switch on the magazine carousel for position alignment or failure.
