Support
Training Videos
Submit a Service Ticket
Return to HURCO.com
Support
Training Videos
Return to HURCO.com
Error Search Result: error_notification_0162
ATC ERROR!! EXCHANGE ARM DOWN INPUT DETECTED, EXPECTED 60 DEGREES INPUT. ENTER “ATC & MACHINE DIAGNOSTICS” TO CLEAR ERROR.
ATC Error. Exchange arm down input detected, expected 60 degrees input. Enter "ATC & Machine diagnostics" to clear error.
Exchange arm expected to be at the down position and the 60 degree input was detected instead.
Check ATC Arm Down & 180 Degrees input.
Check ATC Arm 60 Degrees input.
Check Exchange Arm position switches are functioning properly.
Check for faulty wiring.
