Error Search Result: error_notification_0194
ATC ERROR!! EXCHANGE ARM AT 90 DEGREES INPUT NOT DETECTED. ENTER “ATC & MACHINE DIAGNOSTICS” TO CLEAR ERROR.
ATC Error. Exchange arm at 90 degrees input not detected. Enter “ATC & Machine diagnostics†to clear error.
Exchange arm expected to be at 90 degrees and the input was not detected instead.
Check ATC Arm 60 Degrees and 180 Degrees input.
Check ATC Arm 90 Degrees input.
Check Exchange Arm position switches are functioning properly.
Check for faulty wiring.
