Error Search Result: error_notification_0159
ATC ERROR!! EXCHANGE ARM AT 0 DEGREES INPUT NOT DETECTED. ENTER “ATC & MACHINE DIAGNOSTICS” TO CLEAR ERROR.
ATC Error. Exchange arm at 0 degrees input detected, expected 60 degrees input. Enter “ATC & Machine diagnostics” to clear error.
Exchange arm expected to be at the 60 degree position and the 0 degree position input was detected instead.
  • Check ATC Arm 60 Degrees input.
  • Check Spindle Alarm input.
  • Check Exchange Arm position switches are functioning properly.
  • Check for faulty wiring.
