Error Search Result: error_notification_0193
ATC ERROR!! EXCHANGE ARM AT 0 DEGREES INPUT DETECTED, EXPECTED 90 DEGREES INPUT. ENTER “ATC & MACHINE DIAGNOSTICS” TO CLEAR ERROR.
ATC Error. Exchange arm at 0 degrees input detected, expected 90 degrees input. Enter “ATC & Machine diagnostics” to clear error.
Exchange arm expected to be at 0 degrees and the 90 degrees input was detected instead.
  • Check ATC Arm 90 Degrees input.
  • Check ATC Arm 0 Degrees input.
  • Check Exchange Arm position switches are functioning properly.
  • Check for faulty wiring.
