Error Search Result: error_notification_0024
ATC ERROR – DETECTED TOOL MAGAZINE BOTH UP AND DOWN.
usually caused by debris or another obstruction blocking the sensor. A less common cause is an incorrect configuration causing the control to look at the wrong IO points.
Sensor detects both up and down positions at the same time.
  • Inspect sensors for any debris or obstruction in front of the sensors.
  • Ensure the proper configuration is installed.
