Error Search Result: error_notification_0192
ATC ERROR!! BOTH EXCHANGE ARM AT 0 AND 90 DEGREES INPUTS DETECTED. ENTER “ATC & MACHINE DIAGNOSTICS” TO CLEAR ERROR.
ATC Error. Both exchange arm at 0 and 90 degrees inputs detected. Enter "ATC & Machine diagnostics" to clear error.
Exchange arm 0 degrees and 90 degrees inputs were detected.
  • Check ATC Arm 90 Degrees input.
  • Check ATC Arm 0 Degrees input.
  • Check Exchange Arm position switches are functioning properly.
  • Check for faulty wiring.
