Special case for MPx16: Firmware upgrade to higher firmware version. This error occurs once at first start of drive after firmware upgrade.
Control section configuration not allowed, because an optional module is not supported by firmware
Firmware used is not suitable, i.e. hardware and firmware do not match
Hardware defect on control section
According to instructions, put drive into ready-for-operation status again (see Application Manual ‘Firmware Replacement’). Drive can only be switched to operating mode again after control voltage once was switched off and on again.
Switch drive off and on again. If error occurs again, replace control section by different control section with appropriate configuration. If necessary, contact our service department
Select suitable firmware by means of Functional Description or Version Notes / Release Notes (see index entry ‘Supported control sections’)
Switch drive off and on again. If error still occurs, contact our service department and, if necessary, replace control section or entire drive controller
