Alarm Search Result for: 32834
F8042
Encoder 2 Error: Signal Amplitude Incorrect
- This error only occurs in conjunction with the function: “redundant motor encoder.”
- Because the position is no longer generated correctly, initialize the encoder when this error is detected.
- When using an incremental encoder with square-wave signals, monitoring is carried out with regard to an inadmissible edge. On the software level, resolver signals are monitored for their levels.
- Defective encoder cable or cable shielding
- Encoder defective
- Faulty mounting of measuring head in the case of linear measuring systems
- Measuring system dirty
- Hardware defect on control section of drive
- Check cable to measuring system and replace it, if necessary
- Check measuring system and replace it, if necessary
- Check mounting of measuring head and correct it, if necessary
- Replace measuring system
- Replace control section or entire drive controller
