Alarm Search Result for: 32819
F8033
Ground Fault in Motor Line
The sum of the effective motor currents is monitored for devices of the IndraDrive ML range. The sum of the motor currents is greater than half the nominal current of the device.
Check insulation of motor lines. Check insulation of controller.
