Support
Training Videos
Submit a Service Ticket
Return to HURCO.com
Support
Training Videos
Return to HURCO.com
Alarm Search Result for: 32808
F8028
Overcurrent in Power Section
Drive controller: There is a short circuit at the motor / mains connection
Supply unit: A wiring error has occurred in the mains connection components
Drive controllers connected in parallel: An error has occurred in the parallel wiring of the motor outputs / balancing choke.
Device is defective.
Remove short circuit
Check wiring of mains connection components
Check wiring
Replace device
