Alarm Search Result for: 32801
F8021
Motor Encoder: Incorrect Enc. Signals (Can Be Cleared in PM)
- Since the position is no longer generated correctly when this error is detected, the encoder must be re-initialized.
- When using an incremental encoder with square-wave signals, monitoring is carried out with regard to an inadmissible edge. On the software level, the signals of a resolver are monitored for their levels.
- Defective encoder cable or cable shielding
- Encoder defective
- Faulty mounting of measuring head in the case of linear measuring systems
- When operating a motor of ‘IndraDyn MSM’ type: A fault has been detected in the sending telegram of the encoder; telegram failed twice
- Measuring system dirty
- Hardware defect on control section of drive
- Check cable to measuring system and replace it, if necessary
- Check measuring system and replace it, if necessary
- Check mounting of measuring head and correct it, if necessary
- Faults such as an electrostatic discharge to the shaft of the motor may lead to failure of the encoder sending telegram. Prevent faults.
- Clean or replace measuring system
- Replace control section or entire drive controller
