Alarm Search Result for: 32792
F8018
Device Overtemperature Shutdown
  • Overtemperature (heat sink) due to overload of device
  • Ambient temperature too high. Specified performance data is valid up to an ambient temperature of 40 °C
  • Heat sink of device is dirty
  • Convection is prevented by other components or mounting position in control cabinet
  • Device-internal blower failed
  • Failure of air conditioning for control cabinet
  • Incorrect dimensioning of control cabinet with regard to heat dissipation
  • For liquid-cooled devices: No cooling system connected
  • For liquid-cooled devices: Error in cooling system, e.g. coolant pump defective or filter clogged; thereby flow rate too small / inlet temperature of coolant too high
  • Switch drive off and let it cool down. Check mechanical system and drive sizing (on average, working power may not exceed continuous power of drive) For liquid-cooled devices: Check dimensioning of cooling system (see documentation with part number R911309636)
  • Reduce ambient temperature, e.g. by cooling the control cabinet
  • Clean heat sink
  • Mount device vertically and provide sufficient space for ventilating heat sink
  • If blower fails, replace device or power section
  • Check air conditioning of control cabinet
  • Check dimensioning of control cabinet
  • Connect cooling system
  • Check cooling system and remove error
