Alarm Search Result for: 32769
F8001
Telegram Failure, Power Section Parallel Bus
  • The communication bus between the power parts is faulty.
  • Check wiring and Check grounding. If there are no faults in the wiring and grounding, the paralle connection module (HCP01.1-P001) is faulty and must be replaced
